Received the switch today and installed it with your helpful instructions. Works fine. Thanks!
Noticed the surround/bezel for the switch is different between the '87 and '90--no big deal. Took some photos of the two switches, and you can easily see how some bozo Toyota "engineer" screwed up with his tiny plastic tab attachment thing--there's so little area and strength. I'm surprised I haven't snapped off the one in my '88 Supra.
You can be sure that I'll use very little force on it from now on. Hopefully the clown didn't design anything else.
Benesesso/Cars/Toyota Supra Turbo - Photobucket - Video and Image Hosting
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
