When I re-checked the plugs and wires I checked for fluids in the galleys. Cyl 2 had some, but I think it was from pulling the coolant hose off the intake and not having the rag in the right place to catch it all.
I even went so far as to switch the spark plugs that were in 3 and 5 to 1 and 2 to make sure it wasn't the plugs.
Nope...no change. Still 3 and 5 misfiring (or NOT firing, more accurately.)
The distributor cap is new. Just replaced it on Saturday to make sure that wasn't a problem.
Maybe I'll see if I can post a Youtube video of the engine idling or something. It's weird, because about 1/4 of the time it runs just fine, but I can't seem to tell what makes it kick in and out of that. It's not when it's warm, because sometimes it'll run fine from a cold start, and then kick in later with the misfiring.
I've been reading all day trying to figure out specifically what could be plugged/clogged/bad that would control the firing of the cylinders as opposed to an engine function like idling, and I'm coming up empty.
