I "believe" there is a schader valve in the fitting.
But, you can just unplug the connector and put a jumper in it, and by-pass the switch. I ran mine like that for 3 years.
It is a safety device to shut off the compressor if the pressure gets too high (which is really high).
But there is also a "solder plug" in the dryer that will blow out if the pressure gets that high anyway.
