To fill out Supramacist's answer:
The ignition timing is controlled by the TCCS (that's the computer
). You however can set the base timing by adjusting the rotation of the distributor. A 5? advance over the stock advance of 10? will equate to a 5? increase across the board.
MK3 TSRM On-Line
