Old 04-23-2008, 06:16 AM   #14
supramacist
supramacist's Avatar
I took it down the road and it's obviously working to pull through some hesitation in 3rd and 4th almost as if it needs a tune up.
I just put ngk iridiums in it and the msd wires don't have 2 hours on them.
I know the 1 tooth wasn't an issue so it's throwing effort after want and that's a lose lose.
So I guess I need to remove the upper rad hose after sac'ing up and draining coolant. SO I can fully remove the cam gear cover and make sure everything is at tdc and start from scratch.
I don't know if I do shite the hard way or if this is just life as I know it.
