I've done the starting fluid test already. No noticable revs.
I have the cams and the crank at tdc. So I'm about to put all of that back together...., ya. I"m not done yet. The battery has been unhooked all night.
The throttle is a possibility. My lil bro was in from chicago and tightened some of that up. I thought maybe my butterfly wasn't seating as it should due to over tightening. So I'm awaiting a text on that. The throttle it self sticking? I don't think so. It was giving it to it when I was applying it. I know I'm running rich because I don't have a fuel pressure regulator yet. But this has nothing to do with, I can't get it to idle after operating temp is hit below 1800 rpm's. Hell, it drives it'self in 3rd gear. After I have timed it with the jumper wire. It's like the ecu is running amuck.
How low can I adjust the idle? I may have to move the tooth. I don't know yet. I'm grassping at straws.
I drained the coolant into a gallon jug that had a tad bit of dist water in it.
No oil floating yet so it looks good. But..., I didn't drain it completely. Only enough to get the upper rad hose off.
Something is definitley awry. I'll check back in after I hit another stopping point. Keep them comming I thank you all very very much.
EDIT: What the heck does it mean when the code light flashes consistently with no off sets???
I'm of the opinion that it means it's not throwing codes but i must confess I have not yet looked it up in my tsrm.
Atleast I'm honest.
