Going to '89 motor mounts will require swapping the front subframe or some fabrication work. Swaps are done fairly often, althought the 7M-GTE is a little more popular as parts are a little more readily available and there's more information available. In either case though your best bet would be picking up a front clip as that will have all you need... except possibly the drive shaft.
