Old 04-25-2008, 02:34 AM   #1
supramacist
supramacist's Avatar
Power steering pump bracket. Mine is 2 pieces on my 91 N/A.
That ovular groove is where the nut goes to the pump so you can adjust the tension on the belt.
The bottom back bar connects right to the block down by the oil filter. Again, this is how it is on my n/a.
The front 2 holes attach beneath the t-stat housing. Before you get near the timing belt cover.
