Old 04-27-2008, 02:49 AM   #7
I've never noticed a change in my idle with the base set at 10?, 15? or 20?.
If your idle if off then FIX IT. There's something wrong, the ECU thinks for one reason or another that the idle needs to be bumped and even if you get the timing right something else is bound to be off. There, I'm done... no more help regarding idle and timing issues from me. PERIOD.
