Ok here's the update, i took my car to a speed shop to get my car checked out and fixed and he found a couple of problems, one the spark plugs had oil on them due to a lack of a valve cover gasket so he had to clean it up and reseal my valve cover, and the the timing was WAY! off cause the car probably ran so bad because of the half ass build up he the former owner had to set the time off just to run the car so he set the timing back, the wiring harness is screwed up he patched it up but he suggest i get a new one. Now i need to know where can I find a place to buy a wiring harness???? beside a junk yard
