Old 04-28-2008, 02:51 PM   #1
wbeams
wbeams is on a distinguished road
Smile Weird clutch problem
I replaced the cluch on my 84 supra and when I put it together I couldn't put it in gear when it was running, but I could with it off. I can start it in gear and drive it but can't put it back in gear if I stop with it running. I took it back apart and put a new flywheel in it thinking when I had the flywheel resurfaced they took to much off. I still have the same problem. The cluth is not completely disengaging. It is so little you can't even tell when starting it in gear. I replaced clutch pilot bearing throwout bearing and flywheel. What can it be? Any help would be greatly appreciated. I talked to local Toyata mechanics and they were useless.
wbeams is offline   Reply With Quote
