electric is the way to go!
It doesn't take rocket science to figure out that electrical energy can be obtained much more efficiently than mechanical energy (ok, but does take a little bit of physics). Electric fans is the way to go. It is much more efficient to power a motor via an electric current than a mechanism. Electric fans will get you more air flow with a lower energy requirement. It will take this energy from your battery instead of your gas, so be sure to have a good battery. And you don't need to be an electrical engineer to install them. The circuits are not complicated (reading instructions SOMETIMES helps).
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
