Old 04-30-2008, 12:59 AM   #22
Here, found the info on the plugs for you. MK3 TSRM On-Line
The video could very likely be rod knock, but I've been convinced before that a car had rod knock when it was an exhaust leak. Do like Supramacist suggested and grab a broom stick. If you'd thrown a valve shim you'd know it, listening to the valve cover would be downright painful.
