Old 04-30-2008, 04:44 AM   #23
supramacist
supramacist's Avatar
Yellow can of HEAT.
put in tank. top off. Supreme.
Run it empty.
Here's where I would run it bone dry. Pull in.
Get a can of ATF. insert funnel. add ATF to tank.
fill up. Supreme.
Fill up. Supreme.
Then run that half dry. Top off with your choice of non-leadery.
That was my 1st ever online impression of Tenacious D.
WHY???? I bet you're asking. Every body always asks why.
That is quickley followed by did..., you escape from the local tardery???
The atf lubricates your entire fuel injection system from the inside out it acts as a detergent and a lubricant. It aids in the break down of carbon scoring.
You'll smoke, but never mind they'll all be seeing the smoke soon enough.
Seafoam. Same thing. ATF works better and is half price.
You will notice rather quickley an improved throttle responce and a smoothness to your engine that you have probably never had otherwise known existed.
I promise. I stand by it. It is the mad truth.
Try it once and you can Thank me at your discretion.
No autographs. Hold you applause.
Yes...., I'm in rare form tonight.
