Originally Posted by supramacist
That doesn't sound familiar to me you supramania regular you  .
lol...
Originally Posted by Bill UK
Either side of the oil filter on a turbo block there is the oil feed and oil return pipes, on a N/A block I would assume they blank these off.
http://www.toyota-supra.info/forums/mkiii-supra/11127-supra-head-gasket-questions-rebuild-8.html
The only other parts below the oil filter are the oil return pie from the cooler that goes into the side of the sump and the engine mount. Unless it’s part of that metal plate Toyota loosely fit to the side of the engine, to make you think you have a big end knocking.
Yea, the feed and return spots on a NA block are not open, but the casting spots are there. I took a pic of what I'm talking about :
And this is the casting spot for the turbo oil return feed:
"Stuck in the 80's"
