Not to counter what marc said, but buying a imported engine and not doing a re-build is not always a good idea, the previous owner of my car had a swap done by a local shop with no rebuild, turns out the engine has a valve shim problem and it taps like rod knock. You never know what you are going to get with one.
What you should do is get a stethoscope and listen around the engine to make sure your knocking sound is coming from the bottom end, like I said my engine sounds as if it has rod knock, it even sounds like its coming from the bottom end but when I took a listen with a home made stethoscope I discovered it coming from the head.
If it is coming from the bottom end you are probably going to have to pull the engine and go from there. Good luck!!
"Stuck in the 80's"
