If you think you have rod knock.
Then you probably do. If you don't, you still have serious issues.
Part it out or rebuild it. Entirely. Buy a different engine and rebuild it.
There is no minimal fix for what you probably have.
UNLESS: You locate the knocking and where it's coming from and verify that it's not rod knock.
It could be piston slap...., which "maybe"...., you can get buy with 1 new one but I doubt it. I don't see a 0 mile piston fitting well into a 15 + year old cylinder and having an extended life expectantcy.
Without a complete rebuild. You can monkey with the top end and make things happen.
But the bottom is the factory. Any issue there is not a good one.
