Old 05-07-2008, 09:51 PM   #1
supramacist
supramacist's Avatar
Default Maybe someone can help me here.
I remove all the appropriate items to expose the timing belt.
Now..., flashing back I had just installed a new dashpot onto the tps.
So I'm throwing code 51. I clear it. Time it and it's still funky so I strip it.
With my crank at tdc. My cams are reading 180* out.
I have yet to do much research because I just left the garage. I wanted to ask this Q. Before I even get to where I need to be to research it this evening.
How does this happen and how do I correct it.
I have not been here before and I know I can't just turn the cams without turning everything with out removing the head.
I know I can ghetto it and swap plugs on the dist cap but that is shady as well and isn't the required fix.
Thanks for reading. Any thoughts or comments are welcome.
