Dexcron Mercron
ATF.
Try it as a fuel additive. It's far better than sea foam and cost much less.
EDIT: If you aren't using premium. You're only lubing your fi system.
Wich is fine after you burn it out with a tank of premium.
You'll smoke a bit. Some say that the dexcron reduces the smoke more so than
just good ol regular atf.
I personally never thought it made anything smoke bad enough to worry about it.
I have done this in many autos.
