I understand ya.
Well what had happened was the car was idling up to 2k rpms.
I jump throught the usual hoops.
Track it to the dashpot. Order 1 in. I gave 48$ for it.
Hook it up. Everything running fine. I go for a drive and the idle jumps
back up to 2000rpm's And the timing is shot.
I side stepped it while I work on a larger issue with the engine.
I'm working both angles at once on it.
