Are you speaking of a water fall or rain stick from the mall type of sound?
If that seems close too what you're hearing. It means you have air in your coolant system.
What I would do..., If it were me. So remember these are opinions and there is a reason they are free.
I would drain the coolant system completely. I would even jack the arse end up and get it drained well. Do this with the radiator drain plug open and flowing.
Cork it back up. Fill your overflow up to the right level or your your low coolant light or "birdcage light" will come on and not go off. The engine needs coolant in there to pull back into the system.
If you do this right and you still have issues with the waterfall sound.
Come back and tell us. This..., then. May lead to burping the system wich could a pre-curser to BHG.
