Old 05-10-2008, 10:44 AM   #117
Bill UK
AEM EMS
Bill UK's Avatar
How sure are you that timing is correct, did you strobe it? A strobe light connects to # 6 spark lead and this is the one you suspect being the problem. A spark at the plug can be deceiving; it may not be strong enough to ignite the fuel. If your HT leads, spark plugs and timing are ok, and as you say there are no signs of fuel on # 6 plug then I would check the plug and wiring going to the injector. You could swap the injector plugs over for 5 & 6, pull the igniter lead and turn the engine over to see if any fuel is coming through to either spark plug. I think it’s a question of elimination, if there are no signs of fuel in # 6 but fuel in #5 after swapping over the plugs then it must be the injector.
