I use a similar type solution. If you have lots of metric hardware around find a long bolt, two matching nuts, turn the nuts onto the end of the bolt, and lock them together. If you find its still slipping you can destry the threads of your toyota SST with a flat head screw driver. Might save a trip to the store....
