Old 05-13-2008, 07:39 AM   #129
Bill UK
AEM EMS
Bill UK's Avatar
Another thing worth checking is that cam pulleys are bolted to the camshaft correctly; they should be mounted with the dowel pin in the middle hole. After you have bolted it on and you need to line up the match marks for timing, rotate the pulley and the cam together.
