05-13-2008, 09:03 PM
#131
AEM EMS
No one touches the Supra except myself, I've set the timing dozens of times using # 6 as stated in document below. (# 6 is at the back) if you have a variable setting on your strobe light set it at zero. It sounds if you may have a doggie HT lead. Does the timing advance when you remove the terminal link in the diagnosis box.
