1. I don't condone using cheap parts.
I think we as a collective should strive to use quallity parts to uphold the heritage that is supra.
Just to clear the air. I would only use a cheap one to see if it helps.
That way..., it's only a 20$ if. That you can assuredly return.
Will it aid in running rich? It will certainly monitor the fuel pressure so you can cut it back to make it run "not" so rich.
This is the theory I am operating on.
If I am wrong..., Please correct me. Feel Free.
I'm here to learn as well.
