if you have an automatic transmission, there is a segment of your radiator used specifically for transmission fluid. there are two lines going to and from this spot on your radiator. if they are leaking, FIX THEM. the auto trannys really dont like it when they get hot. even though you can find another one for like $200, its the labor to swap it out.
the exhaust gasket thats leaking should have nothing to do with your running too rich. depending on your mods, youll run rich anyways. the only thing the gasket will do is possibly make the cabin smell, and make the exhaust a lot louder.
my car:
1987 brownish Toyota Supra Turbo, automatic 7MGTE engine with ~100k miles on it.
