Thread: Raising Idle
Old 05-19-2008, 03:11 AM   #2
CyFi6
Idle should be 750-900 rpm. You can adjust it with a little screw thats on your throttle body, under a little black rubber cap. Pull the cap off and use a flatblade and unscrew the little screw a little bit. Make sure your timing is right and your ISC valve is clean also.
