Old 05-20-2008, 09:09 PM   #1
spudz29212MKIII
spudz29212MKIII's Avatar
spudz29212MKIII is on a distinguished road
Default Prop/Drive Shaft, brake question
I replaced front rotors and pads, little bubbles in the lines but we bled it. When I am coast'n down a hill in idle I can still hear the front brakes drag at a certain point. And it gets worst when going around a curve.
Ya'll think air might still be in the lines, or could I have a wheel bearing bad? Up on the lift the tires did not move barely at all when you move top, bottom back to forth.
Next inquire;
Well when we had the car up on the lift I was just checking around and came upon the propeller shaft. (note; no weight on any tires or suspension) When I put my hands on either side of the center bearing I could lift the shaft up and down like a 1/2 in to an inch.
Is that normal? I thought the shaft should not move at all if its bolted to axel and tranny (even if its a two piece). New center bearing?
Also, info why I think its bad; car still has little vibration on highway speeds, and some times a really rough shift when tranny engages like a big clunk sound. Almost like the shaft is jumping up at the bearing. The support braket looks like it has taken some twisting stress.
Thanks guys
Zach
spudz29212MKIII is offline   Reply With Quote
