Old 05-21-2008, 02:46 AM   #52
spudz29212MKIII
spudz29212MKIII's Avatar
spudz29212MKIII is on a distinguished road
No prob, But pretty simple. I just used the compression testr' hose. What you need to do is popp off the gauge and hook up the air. Now there is a little nozzle in the end to keep air in (like a tire or bicycle stem nozzle). So instead of getting another hose I just got some small tweezers and you basically can just screw it out. I dont actually remember the size of the fittings (i just have a ton laying around) so just play around but I know advance auto parts has the right fitting.
Dont loose the little nozzle, but if you do its the same nozzle as in a tire's stem. (you just might have a pain in the ass fitting it or finding the right size)
Zach
spudz29212MKIII is offline   Reply With Quote
