Your last post indicates starter motor or the thin wire going to the starter being the problem. Try this first; connect a wire (about 15 – 20 amp) to the small spade connector on the starter motor, there are only two wires going to the starter, (both are positive) one large red wire which is bolted on to the starter and one thin one that is connected to a brown shielded spade connector. The other end of the wire temporally insulate, you may find it easer to leave the existing small wire connected and just crimp or solder the extra wire as close as possible to where it connects to the starter. Turn on the ignition (make sure its not in gear) remove the temporary insulation from the new wire and touch the positive terminal on the battery. If it does start and you continue to have success, let us know.
I think the shock may be just static electricity some people are more sensitive than other to static. Try wearing cotton undies instead of nylon.
