Old 05-24-2008, 05:40 PM   #5
f00g00
Thats pricey and doesn't include the harness, (its probably cut on that one where it would have gone through the firewall) or the ECU which you will need since your swapping to a different motor, and you will need the ignition system and modify the tach on your NA dash etc etc.
There are a ton of posts on the swap.
