Old 05-30-2008, 12:20 AM   #27
CyFi6
input: Take the engine out. Theres no point of leaving it in if everything is already apart, theres hardly anything keepin it in there! You are going to have a much higher chance of damaging expencive internal parts if you do it from the bottom, and you will likely end up with more issues than you started with. You should probably at least get the block honed out equally if measurements come out into spec.
