Thread: Running Hot
Old 05-30-2008, 11:27 AM   #15
Chambers
Chambers's Avatar
You could buy a new engine, but it wouldn't be smart to buy one and not do a rebuild, because that engine might have a bhg as well. Either way you are going to have to tear down a engine to see whats wrong if anything.
I would suggest you get the crank checked to see if it is withing tolerance of the TSRM, if it clears then you can do a rebuild on the engine you have now and keep your engine.
"Stuck in the 80's"
