Thread: Engine cuts out
Old 06-03-2008, 07:19 PM   #10
supradaddy0803
supradaddy0803's Avatar
I have had this problem before and my negative battery clamp was broke and would work itslef loose during the expansion of the battery terminal when it warmed up. Then when it cooled down it would reseat and work just fine. Try to grab it and turn it if it moves then you need to try to tighten it or if it is broke replace it. Another symtom of this is when you turn the key you will lose all of the lights on the dash and everything pretty much.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
