I'm not sure how you have managed over 500 posts and 2 years at this site and are still not sure where to get rtv
. Let alone where it goes.
I don't mean to be rude or anything but c'mon.
You get the rtv at the same place as the molly. Use loctite brand.
Do you remember when it was all tore down and it was just your block?
Good well on the very front nose up by where the timing belt goes.
There was a hole. You couldn't miss it with the MHG top side the block.
To the best of my knowledge...., that's the only place it goes that I am aware of.
I have to prod you here to stop asking to be spoon fed. And learn how to wield your car.
You need to research. If you don't you're not only cheating yourself, but your car as well.
It's no use working on it yourself if you're not going to learn anything before hand. Because when it breaks from shoddy mechanicing.
It's going to cost you the same amount or even more to fix it right.
Not to mention the time you have waisted because you didn't form your own conclusions or thought process because you were to busy asking every one what was what instead of learning about it along with the rest of us.
