20 - But this one is a little more disconcerting.. It looks important, can anyone tell me what this is too and whether I should be concerned?? (It will be fixed, but it looks like a difficult thing to work on atm..) The oil filter on the right is the best reference I can give as far as where on the engine this disconnected ______ is. What ever it is, it looks important..
21
22
23
24 - Yeha the rod that connects to the turbo is loose enough to move, but not enough to rattle where it's at.
25 - This tube that is crackededed and worn, what is it for specifically and can I just replace it with the proper type and length of hose or do I need to find a specific part to replace that?
26
27
28 - The two white connectors were just sitting disconnected, what are they for?
29
30 - Yeha this filter needs to be replaced...
31
32
33
34
35
36
37 - A much better shot of the disconnect..
38
39
That should be enough to keep y'all busy.
Thanks in advance as all help is greatly appreciated.
Sorry about all the thumbnails, I will post the direct links in the future to avoid the limit stuffs.
