Unplugged or plugged in its not doing anything as it is, the two wires that are connected are heater wires for the ox sensor, the broken wire is the sensor/signal wire, you really need to connect that back up. Not sure if soldering is advisable as the wire may be used to measure resistance back from the sensor.
