Originally Posted by kwayne
Which warning light are you seeing? Can you post a pic? The reason I ask, is I was getting an amber warning light whcih I thought it was open hatch warning light. But, it turned out to be the illumination warning light. The problem was corroded grounds on the tail lights.
Try removing the tail light assemblies. They just snap out. Removing the ground wires, cleaning the contacts and reassembling.
THANK YOU... It was the illumination warning... I will be hunting down the problem tonight
