Old 06-10-2008, 03:16 PM   #10
rebstew
rebstew is on a distinguished road
Originally Posted by Chambers View Post
Wow, I haven't seen that swap before, what tranny are you using? AOD, C4, or C6?
It has the AOD in it. Also sports the Ford gauges in the dash. All the computer stuff is hooked up. A Lincoln intake was used so everything would fit under the hood. The Lincoln's throttle body sits in the back of the intake where the Stang sits where a Carb would sit on a older car. With the other intake you don't have to run a scoop to hide it from sticking out. it is running straight pipes on it now which isn't too bad untill you hit the loud pedal. I need to check into some cheap mods for the 4.6 after the body work is done. I think the computer has been reworked already but I'm sure there's more on tap. Maybe even??
rebstew is offline   Reply With Quote
