Old 06-12-2008, 01:40 AM   #2
Chambers
Chambers's Avatar
I'm not sure if there is a fuse for it but thats where I would look first, a good friend of mine in his Rodeo took two weeks of hard work and waiting for parts to get his tank down, get the old sending unit out, put the new unit in, and finally getting the tank back up. In the end it was just a fuse that blew.
If that comes to no avail, then I think you can get to the sending unit through the hatch. I haven't had to do anything with the fuel tank in my car so far so I'm not so sure if you can get to it through there.
Hope this helps, good luck!
Edit:
The TSRM says to drop the tank to access the fuel pump, so I guess you will have to drop the tank if you need to replace the sending unit.
"Stuck in the 80's"
