For your question. The heat shield should be facing down. The only way i have seen to identify the front/rear of the cat is to look at the openings. The front of the cat has a little bit of protruding pipe sticking past the flange, whereas the rear of the cat does not, and it just a hole. Unless you see a marking of some sort with an arrow and or an F or R
