Old 06-16-2008, 09:05 PM   #2
mrnickleye
mrnickleye's Avatar
Wrong (cousin)
The oil comes from the valve cover gaskets, or the center gasket that runs down the middle, over the spark plugs.
When the oil fills up the spark plug hole (around the plug), it will cause a misfire because the spark will ground out .
Pull everything out of the way, and replace those gaskets. The dealer is the only one that will have the center one ($38).
