Old 06-16-2008, 10:04 PM   #1
yotatime911
yotatime911 is on a distinguished road
Exclamation 1986.5 supra turbo engine cutting out
my car is cutting out at about 3000rpm under a load but not in neutral. I replaced camsensor,plugs,wires,coils so its got good spark bt that didnt help. So i did a compression test and the cyclinders all showed good compression at 140psi +or- 5psi. i also know that the fuel pressure regulator is working properly 2 so i am pissed what else should check.
yotatime911 is offline   Reply With Quote
