Old 06-19-2008, 07:19 PM   #2
supradaddy0803
supradaddy0803's Avatar
I am not sure that the 1JZ cams will work. Also depends on what 1JZ you have if it is the VVTI then you are pretty much out of luck. Which cams are you looking at?
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
