Old 06-23-2008, 04:03 PM   #6
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Exclamation
i'm not sure if you meant that when you corner or turn that the steering is stiff or if you mean that the "vibration" is what makes it diffucult.
Did you check your ball joints? If they are bad then you will get movement between the parts when cornering and eventually they will break off and then you're really screwed.
I would stop thinking pump and look over the entire suspension system.
robertsws is offline   Reply With Quote
