Yea, that reminded me, I had a similar problem with a light going out and then coming back on later. I took some WD-40 and sprayed the entire light assembly's and the light failure box, that solved my problem because of the water running down behind the tail light from the hatch was causing a bad connection.
"Stuck in the 80's"
