I agree with bill here.
The least you should do is a toyota oem replacement gasket and still use ARP studs.
If you can't afford to do this right for as close to a permanent fix as possible...., I wonder how you intend to keep it on the road at all.
Because cutting corners is nothing more than a band aid and a cheap off brand of at that.
