won't idle
89 na manual. will not idle. I've replaced the tps, and it fixed the high idle problem I was having, tried putting the old one back and didn't change anything. I can keep it running by raising the rpm, but on its own it just drops and dies. out of gear it idles rough while I hold it, but in gear it goes through the whole rpm band with no problems... fuses all fine, can't check the timing cause it won't idle, but it just passed emissions, and I don't think the timing belt jumped cause it runs just fine off idle
Cometic MHG, ARP studs, H&R lowering springs
