I was having the same problem with my na, I didn't play with the idle screw so I would suggest setting that back to factory, and replace your tps. granted I have the na, but I bet that will fix it. check your timing also, advanced timing will jump the idle.
Cometic MHG, ARP studs, H&R lowering springs
